Activity Forums Adobe After Effects Rendering problem in 720p
  • Rendering problem in 720p
    Posted by David Supan on May 21, 2009 at 4:40 am
    Hi!
    I’m working on a project for my school. It includes a few videos with no effects – several minutes in length -, a few videos with chroma key plugins applied – no more than 20 seconds in length – and a few segments of motion graphics. I chose to work in After Effcts because I wanted better control over transitions between segmentss so it is all composed in a single composition.
    I have running PC on Windows Vista Ultimate with 4 GB of RAM, two ATI graphics cards with 512 MB RAM each, a quad CPU and more than enough of disk space. The 3GB switch is also active.
    The problem comes up with the rendering process.
    For the sake of quality, I wanted to render the final project to an uncompressed AVI file, which would be approximately 14 GB in size.
    From there on I could compress to any other video container using Adobe Media Encoder.
    But nothing goes according to plan. Whenever I set the project to render, no matter which container is set on the output, the After Effects crashes in a matter of minutes. To avoid the problem of lack of RAM, I tried rendering audio only – which went well – and then single frame sequences to TIFF. The same problem comes up – AE freezes in a matter of minutes.
    What should/could I do to render the project properly? Any help would be appreciated.
    Just one of my many sigs:
    The American people have always had problems with the immigrants. Ask American Indians… XD
    David Supan replied 17 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
