Activity › Forums › VEGAS Pro › Rendering problem
  • Rendering problem
    Posted by Zuzana Samuel on January 14, 2019 at 10:39 pm
    Hello everyone!
    I apologize in advance for maybe sounding uneducated but at this point, I’m desperate:
    I have got a new laptop in which I’ve installed a Sony Vegas (thing I’ve done many times before as I change my computers quite frequently). I instal SV 16 and as SV 14 user so far I am pleasantly surprised that it opens .avi files with sound and so on.
    I start a new project, cut it, add coloring and want to render and that’s when the problem comes on: my 15 seconds video will render for over 17 hours (the clock haven’t stopped counting up, I just cancelled the rendering after 15 minutes).
    I tried different settings, nothing worked, always the same issue. Okay, so I tried SV 15, nope same problem and so I went back to SV 14 and still the same problem. I tried to uninstall the Sapphire plug-in, hoping it might be just incompatibility issue but no luck.
    Long story short, by trial and error I found out that the problem is with coloring, or more specifically all the non sapphire plug-ins. I can render video without adding color correction, curves, brightness and so on. I can add all the sapphire plug-ins including transitions as well. But the moment I try to add simple black/white plug-in in just one frame I’m not able to render a video.
    Has anyone answer for this?
    Of course I tried to search it up first but I’m not exactly sure what I’m looking for… maybe I am missing a remotes? Or my graphic card is incompatible?
    Thanks ahead for any kind of answers.
    Graham Bernard replied 7 years, 8 months ago 3 Members · 2 Replies
  • George Dean
    January 14, 2019 at 11:52 pm
    Can you post screenshots of your project properties and render format template settings.
    Have you tried Options > Preferences > Video (tab) ‘GPU acceleration of video processing: to ‘OFF’?
    Best Regards……George
  • Graham Bernard
    January 15, 2019 at 6:12 am
    Apart from George’s requests for information, please use the MediaInfo freebie to tell us exactly what is inside that AVI. Also, a list of the FXs you’re using. How much SPACE do you have on your LAPTOP?
    * Grazie
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
