Activity Forums VEGAS Pro Rendering Problem
  • Rendering Problem
    Posted by Christopher Skraba on September 12, 2009 at 9:23 pm
    I’m currently rendering a short film that’s 15 min long. However when I render it, it only renders to 9:03. But it will play the rest of the video after 9:03 however it skips in the final project. Like a CD that’s been listened to way to much. I’m rendering as an avi file in widescreen.
    John Rofrano replied 17 years ago 2 Members · 1 Reply
  • John Rofrano
    September 13, 2009 at 11:54 am
    Do you have a loop selection around that first 9:03 and when you render, do you have Render loop region only checked? This might be what’s making it stop. Also how big is the rendered file? If the hard drive that you are rendering to is is formatted for FAT32 (as many external drives are) you can’t render a file larger than 4GB. You need an NTSF drive to create larger files.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
