Activity Forums Adobe After Effects rendering problem
  • rendering problem
    Posted by Yair Neumann on October 15, 2008 at 12:14 am
    Im getting an error message that says
    “unable to allocat space for a 4037×2291 image buffer”
    I tried decreasing the max RAM Cache size value and I selected the enable cache option but that doesnt solve the probelem, do you have any idea what I shoud do?
    Kevin Camp replied 17 years, 11 months ago 2 Members · 3 Replies
  • Kevin Camp
    October 15, 2008 at 4:05 pm
    generalspecialist.com has a fairly comprehensive list of things to do to avoid this error. you’ve already done a couple of the usual fixes, but there are several other fixes to try.
    the article is older, but all of those tips are still valid. one other that is not on there, would be to disable multiprocessing if you are working in cs3 or higher. this should also leave more ram available for the image buffer.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Yair Neumann
    October 15, 2008 at 6:16 pm
    The link that you posted is broken, theres nothing on that page. Do you have any other links I can check?
  • Kevin Camp
    October 15, 2008 at 7:16 pm
    sorry, try this:
    https://generalspecialist.com/2006/11/avoiding-after-effects-error-could-not.asp
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
