Activity Forums Adobe After Effects Rendering problem
  • Rendering problem
    Posted by Marc Lucas on February 21, 2012 at 3:58 pm
    Have an issue where AE is only rendering out a few frames of a 5 sec camera animation using Camera Mapper. Not sure what is going on maybe something to do with OSX 10.7.3? I don’t think AE is happy. My timeline range is set ok with B & N is there a place where you can set a custom length of render like an IN & Out in FCP
    Marc Lucas replied 14 years, 7 months ago 2 Members · 2 Replies
  • Walter Soyka
    February 21, 2012 at 4:16 pm
    [Marc Lucas] “Have an issue where AE is only rendering out a few frames of a 5 sec camera animation using Camera Mapper. “
    Does AE think it’s completing the render successfully, or is it failing with an error?
    [Marc Lucas] “My timeline range is set ok with B & N is there a place where you can set a custom length of render like an IN & Out in FCP”
    Yes, there is. In Render Queue, select your render item, click Render Settings, and confirm that the range matches your work area.
    When you add an item to the render queue, AE defaults it to the work area. However, if you duplicate a render queue item, AE copies its existing output range. If you interrupt a render, then duplicate it in the render queue, AE will keep its modified range from the interruption instead of the default work area.
    Walter Soyka
  • Marc Lucas
    February 21, 2012 at 4:19 pm
    Not getting an error message just one frame of the 5 secs of the render
