Activity Forums VEGAS Pro Rendering picture compilation
  • Rendering picture compilation
    Posted by Zaphod on October 28, 2005 at 5:03 am
    i put together a picture compilation of about 50 pictures with a music track and then tried to render it as an mpeg-2 file. the total play time of the compilation is about 6 minutes. the rendering process took a surprising 1 second and produced a file of equal length that showed nothing. i tried several formats with the same result. am i missing something obvious?
    thanks.
    Chris Borjis replied 20 years, 11 months ago 3 Members · 2 Replies
  • Steven J casey
    October 28, 2005 at 5:23 am
    In the render options box make sure you don’t have “render loop region only” checked. Sounds like this may be the problem.
    steven
  • Chris Borjis
    October 28, 2005 at 4:06 pm
    you could also double click below your tracks and
    then the loop region would select your entire timeline.
