Activity Forums Apple Final Cut Pro Legacy rendering out mov with alpha
  • rendering out mov with alpha
    Posted by Jason Leue on December 22, 2009 at 2:19 am
    I’m trying to export some footage from fcp with an alpha channel. I was wondering how to do this.
    I exported with compressor as a tga seq and that worked but QT and fCheck both wouldn’t let me save it out, they both said that I don’t have permission. I don’t get that.
    So now I wondering what method works for exporting out to get an alpha channel?
    Jason
    takes 10,000 hours to master something
    Alan Okey replied 16 years, 8 months ago 3 Members · 6 Replies
  • Alan Okey
    December 22, 2009 at 2:42 am
    If you are on FCP 7, you have two options: ProRes 4:4:4:4 or Quicktime Animation with \”millions +\” selected (the plus is for alpha).
  • Arnie Schlissel
    December 22, 2009 at 2:49 am
    [jason leue] “QT and fCheck both wouldn’t let me save it out, they both said that I don’t have permission.”
    you need to check the permissions on the disk or folder you’re trying to save the QT in. That needs to be set to allow you to write to the directory. You do this in the Finder using “Show Info”. Consult the Finder help menu if you need more help.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Jason Leue
    December 22, 2009 at 3:55 am
    thanks for the quick replys
  • Jason Leue
    December 22, 2009 at 4:04 am
    i have fcp 6
    can i still do in fcp?
    i have compressor too
  • Jason Leue
    December 22, 2009 at 4:05 am
    i don’t have permission fr the operation, the disk is shared.
    thanks
  • Alan Okey
    December 22, 2009 at 6:35 am
    [jason leue] “i have fcp 6
    can i still do in fcp? “
    You can’t output ProRes 4:4:4:4 in FCP 6, but you can still output Quicktime Animation with millions of colors +. That is your only choice for a codec that supports alpha channels in a Quicktime .mov file.
