Activity › Forums › Adobe After Effects › rendering out keyed section with alpha….so I can re-import
  • rendering out keyed section with alpha….so I can re-import
    Posted by Michael Duff on October 31, 2005 at 10:08 pm
    Hi all,
    I’ve got a job that requires a lot of keying, and compositing into a 2.5D world. I’m hoping to pull a good key, render out with an alpha, then re-import….so that hopefully my work speed is increased. Just wanting suggestions on the best method to render out the key. I know I need to use RGB+A, and I was thinking animation codec or uncompressed. But I don’t really understand the “straight” vs “premultiplied” bit.
    Any tips…..
    Michael Duff –
    Southern Cross Ten, Australia
    Michael Duff replied 20 years, 11 months ago 2 Members · 2 Replies
  • Steve Roberts
    October 31, 2005 at 10:10 pm
    It depends on where your movie is going after AE. Avids need straight alpha, but other apps can accept both. Straight is probably your best bet.
    But … if opened in some apps, the edges can look really weird until you tell the app that the alpha is straight. Then it’s okay.
    Steve
  • Michael Duff
    October 31, 2005 at 10:27 pm
    I’m re-importing in AE….just so that when I build the world around the character it will render quicker. So will try straight and see how it looks.
    Cheers
    Michael Duff –
