Activity › Forums › Adobe After Effects › Rendering movie to import into a Final Cut Pro document
Posted by Zebsophia on November 9, 2006 at 5:36 pmHow do I prepare and output animation created in After Effects to import into a Final Cut Pro project? Thank you.
Zebsophia replied 19 years, 10 months ago 2 Members · 3 Replies -
Zebsophia
November 9, 2006 at 6:49 pmCamera: Canon GL2
Computer: MAC G5
Software:Final Cut Pro HD
Footage:
720 x 480 (1.20), Separating (Lower)
Millions of Colors
DV/DVCPRO – NTSC
48.000kHz / 16 bit / StereoI am new to this process; please let me know other information you will need. Many Thank you very much for your help.
Tony Kloiber
November 9, 2006 at 10:18 pm[ZebSophia] “720 x 480 (1.20), Separating (Lower)
Millions of Colors
DV/DVCPRO – NTSC
“Well there is the info you need to know. Set your AE comp to those settings (or use the preset) and animate away when you come to the point of rendering make sure your output and render templates (Edit>templates) are set to these settings as well.
If what your doing is going to be layerd over footage that is in FCP use a setting in the output template that has an alpha channel (i.e. preset -losses with alpha).
TonyTony
