Activity Forums Apple Motion Rendering Motion Movie with Alpha channel
  • Rendering Motion Movie with Alpha channel
    Posted by Darren Mcfarlan on June 7, 2006 at 12:26 pm
    How can you, or can you render out a movie in Motion, on an alpha channel?
    I do this all the time in LiveType, and would like to render some particle effects in Motion, and bring them into AE, and place them over some video.
    Every time I render something in motion, it is on a black background.
    Darren
    Ben Dickson replied 20 years, 3 months ago 4 Members · 3 Replies
  • Doyle Rockwell
    June 7, 2006 at 12:38 pm
    Heya,
    When exporting a Quicktime, are you using a codec that supports alpha? DV, for example, does not. You will need to use a codec like Animation.
  • Greg Niles
    June 7, 2006 at 4:40 pm
    In the Export dialog, there is a popup labeled “Export Preset”. Usually it is set to “DV NTSC Movie”, but you can change it to “Lossless+Alpha Movie” to get a QuickTime movie with an alpha channel.
    — Greg
  • Ben Dickson
    June 22, 2006 at 7:38 am
    Possibly place a white or black backdrop and then use multiply or screen to take oujt that colour.
    …:: Gromfilms.com ::…
