Activity Forums Adobe Encore DVD Rendering Motion Menus in Encore – Photoshop File Error -1
  • Rendering Motion Menus in Encore – Photoshop File Error -1
    Posted by Ben Miller on January 30, 2014 at 3:13 pm
    I recently upgraded to Mavericks. I’m afraid that’s the answer on how to fix this problem.
    Everything is working fine, except when I try to render a motion menu.
    I found that if I delete ALL the buttons, it’ll work, but when I try to put a new button, the program will crash.
    BRAND new install of Mavericks and CS5.5
    I put together a quick screen capture to show the problem:
    https://www.youtube.com/watch?v=PfX6W0LmwTE
    I’d love some help on this!
    -Ben
    Robert Muhammad replied 11 years, 6 months ago 3 Members · 3 Replies
  • Daniel Ludwig
    February 1, 2014 at 9:39 am
    Ben,
    first of all – there´s something weard with your project.
    I´ve seen 100GB BD-ROM-content, while you not selected any BD-ROM-content. the disc is MORE than full. that might be the first issue.
    2ndly to use WAV-audio is no good choice, well it works better with BD but it is a big mess with DVD. 95% of all DVD-player-issues I´ve ever seen came from uncompressed PCM-audio.
    your menu seams to be ok, so far as your screen-grab showed, but in detail this could only be verified when looking at it in detail.
    teamviewer would be a good way to do so.
    cheers
    danny
  • Robert Muhammad
    March 30, 2015 at 4:33 am
    Ben, Did you ever find a fix for this problem? I am running Encore 5.1 in Yosemite and getting the same “photoshop file error -1” when I try to burn a DVD with a motion menu. When I use the same .psd file to make a static menu, I dont get the error.
  • Robert Muhammad
    March 30, 2015 at 4:53 am
    OK, problem solved!
    For some reason, in Mavericks & Yosemite (God bless Apple!), you have to rasterize type layers in your menus in Photoshop before creating a motion menu with them in Encore. I found the answer in the following post:
    https://forums.creativecow.net/thread/145/873099
    I’m Transcoding now. Hopefully it will complete and burn successfully. If any problems, I’ll follow up this post with another. Otherwise, Problem solved 🙂
