Activity Forums Maxon Cinema 4D Rendering more than one camera at the same time
  • Rendering more than one camera at the same time
    Posted by Stu Pond on May 3, 2006 at 12:38 pm
    I have a globe that I am doing multiple animations of, with cameras panning across the surface. For simplicities sake I have animated all the cameras in one file. Each one is set to start at 0 secs and has varying durations.
    Is there an easier way of rendering this from one file, or do I have to create several version of the same file and batch render?
    Stu Pond replied 20 years, 4 months ago 2 Members · 2 Replies
  • Arndt Von koenigsmarck
    May 3, 2006 at 5:07 pm
    It depends on the kind of animation in your scene. One solution would be to offset the animations of all cameras so you can use the stage object to jump from one camera to the next and render it all out as a movie or an image sequence.
    Kind regards,
    Arndt von Koenigsmarck
    https://www.vreel-3d.de
    https://www.vonkoenigsmarck.de
  • Stu Pond
    May 4, 2006 at 8:30 am
    I had thought of that, but I need to render the sections out as separate movies to keep the edit flexible, so I guess it’s the donkey route!
    Thanks for your help,
    stigWeard
