Activity Forums Apple Final Cut Pro Legacy rendering master clips
  • rendering master clips
    Posted by Peter Brusikiewicz on December 24, 2005 at 7:35 pm
    I have captured footage and imported it to a final cut project. All the masterclips that I have are in my browser window, and they play in real time in my viewer slug. However, whenever I add a clip to my timeline, I have to render it. Anyway I can just prerender the masterclips in my browser window? What can I so to stop this? I find it really time consuming.
    Nick Meyers replied 20 years, 9 months ago 3 Members · 2 Replies
  • David Bogie
    December 25, 2005 at 4:55 pm
    [peterb] “What can I so to stop this? I find it really time consuming.”
    To be charitable, I will tell you that your sequence settings must match your clip settings precisely. You can achieve this by looking in the index or online help system for the terms or locate them in the menus. There are presets for all common formats but you have not told us what your format is.
    Tip to save you some frustration and another post: You cannot change the settings of a sequence while it’s open so just start with a new one.
    Your post indicates a couple of things:
    1. You’re new.
    2. You bought a product that is unbelievably complicated but you think you can wing it.
    3. You installed FCP and fired it up without reading anything of value in the five book set of manuals.
    4. You started your first project without doing the tutorials.
    Save yourself endless frustration and wasted posts. Stop what you’re doing and take a month or two to learn the application. You cannot imagine how complex FCP is and how difficult it can be to get the simplest things done. Once you understand the basics, you’ll be surprised how quickly and easily you can get the most complicated things done.
    bogiesan
  • Nick Meyers
    December 26, 2005 at 9:44 pm
    actually, you CAN change most of a sequnces settings even if there are clips in it.
    only one will NOT change, and that’s the Frame Rate.
    So if you need to change from PAL to NTSC, say, you;re out of luck.
    But if you need to change from DV PAL to DV Uncompressed, all’s well.
    nick
