Activity Forums VEGAS Pro Rendering Makes A Short Black Video??? Advice? :(
  • Rendering Makes A Short Black Video??? Advice? :(
    Posted by Leaf Mountain on September 6, 2014 at 1:34 am
    SO i have sony vegas pro 12, i played around and made a youtube intro 20-ish seconds long. I have the Project Video Properties set to Match Video Media… which makes a custom rendering template- though ive tried without. whenever i try to render, as a avi. mp4. etc it renders in 2-3 seconds and gives me the desired file of only a few thousand kb…when i play it it gives me a black soundless video only a few seconds long. Im running windows 8 does anyone know whats wrong??
    UPDATE: I switched compatability settings to windows 7, but now it just renders halting videos with the audio cutting out… maybe this is just the fault of my computer?
    Graham Bernard replied 11 years, 12 months ago 3 Members · 2 Replies
  • Derek Moran
    September 6, 2014 at 4:22 am
    Hi Leaf
    It sounds like you have “Render Loop Region Only” turned ON by mistake.
    This is one of the most common problems people experience.
    The setting is near the bottom of the Render As window.
    Turn it OFF and re-render and everything will be back to normal.
    You don’t need to be in compatibility mode.
    Regards
    Derek.
  • Graham Bernard
    September 6, 2014 at 5:34 am
    [Derek Moran] “It sounds like you have “Render Loop Region Only” turned ON by mistake.”
    Sure, that IS a possibility, but I’d want to know FIRST that the OP has a Loop Region Selected on the Timeline – yes? Otherwise our chum could be rendering the WHOLE Project, to no avail.
    A ScreenGrab of the Work-area would nail this.
    Grazie
