Activity Forums VEGAS Pro Rendering low fps second (slideshow effect)
  • Rendering low fps second (slideshow effect)
    Posted by James Fox on December 26, 2011 at 5:28 pm
    I am rendering AVCHD clip. I havent had low memory before while rendering, but now I try to render a clip with fps setting set to 2 frames per second and I get “The system is low on memory. You may be able to reduce memory usage by closing other applications” error. Is it normal ? I didnt expect that rendering on lower fps could make any changes for memory usage. My laptop has 4GB ram on win7 32bit.
    I am trying to make so to say “slideshow effect” not a smooth video with high fps. And tried this way, so you could also say any other tips how to delete frames or make such slideshowy video.
    James Fox replied 14 years, 8 months ago 2 Members · 4 Replies
  • John Rofrano
    December 26, 2011 at 7:18 pm
    [James Fox] “My laptop has 4GB ram on win7 32bit.”
    Since you are using a 32-bit OS you can only use 2GB of memory so out of memory problems are common in 32-bit mode; especially if you have multiple cores.
    [James Fox] “I am trying to make so to say “slideshow effect” not a smooth video with high fps. And tried this way, so you could also say any other tips how to delete frames or make such slideshowy video.”
    Try setting the Undersample rate in the event properties to 0.100. That will get you down to about 3 fps.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • James Fox
    December 26, 2011 at 8:34 pm
    It seems that 0.100 is the minimum?
    My footage is 50 fps, so it gives me 5 fps, but I cant set is smaller, it just goes back to 0.100.
  • John Rofrano
    December 27, 2011 at 1:49 am
    50fps… Wow. Why record at such a high rate if you want to make it look like a slide show? Pixelan has a plug-in called StepTime that will also slow footage down like a slide show. You might want to look into that.
    ~jr
  • James Fox
    December 27, 2011 at 1:03 pm
    I believe it might look weird 🙂 Its a sport camera and so the higher fps the better, my camera also has a picture mode to take picture in every 1 or 2 seconds(called timelaps i believe?). So I had some pictures of cardrive to a campsite and few videos of the same drive, And it set the pictures with length 0.145second and got pretty cool clip that way, but I didnt have very much those images, so I thought to make video look like similar.
    Thanks for the tip I will check soon I got on right computer!
