Activity Forums Adobe Premiere Pro rendering just a part of a a clip
  • rendering just a part of a a clip
    Posted by Mike Tyler on May 30, 2017 at 2:46 pm
    I wasn’t sure how to title this…
    Basically, I’ve rendered out the whole project / video and found a mistake at one spot – is there a way to not have to render out the whole sequence again ?
    When working in After Effects, I always rendered out as images.. so in this case, I’d just render out the images at the spot where the problem was.
    But I don’t think this is possible with video, right ?
    Dan Powers replied 9 years, 3 months ago 2 Members · 1 Reply
  • Dan Powers
    May 30, 2017 at 8:56 pm
    Did you render and export it out to a pro res file?
    Unclear if you are talking about rendering a bunch of effects on the timeline or a full export.
    If just multiple effects, you can fix just what you need and it wont disturb the others unless, you have another element that connects them all, like a lower third super or an adjustment layer and still the smart rendering works pretty well.
    IF it is a whole timeline export, No. You are going to have to re-export out that file.
    IF the timeline is rendered, choose to USE PREVIEW FILES when exporting and it will speed up your export.
