Activity Forums VEGAS Pro Rendering Issues
  • Rendering Issues
    Posted by Casey J porter on February 10, 2009 at 2:14 pm
    I have been using Vegas 9 for some time now and still can not figure out what is probably something very simple: How do I render a film at 4:3 in the highest resolution possible? If I render in WMV 3 Mbps at 640×480, the format is right, but the picture quality is not good at all. How can I render in a higher quality without Vegas putting it into a Letterbox format? If I click “Stretch video to fill output frame size (do not letterbox) it just stretches the picture. I am rendering a custom version of a trailer I am working on right now, but am looking for any help that might be out there.
    Thank you,
    Casey J Porter
    http://www.youtube.com/caseyjporter
    Jeremy Rasnic replied 17 years, 7 months ago 3 Members · 5 Replies
  • Jeremy Rasnic
    February 10, 2009 at 3:14 pm
    I don’t believe the consumer version of Vegas allows for custom bit rates. This is a feature that is readily accessible in the pro version. I believe you are limited to the templates they give you. However, if you are wanting to render out to wmv, I believe you could download the trial version of Vegas 8pro and give it a whirl and produce a higher bitrate (better quality) wmv file.
    j razz
  • Casey J porter
    February 10, 2009 at 3:27 pm
    Thanks for the quick answer. However, there are advanced setting and I am playing with those. I am not set on any one file type, whatever will get me the best looking results without putting it into Letterbox.
    Thanks Again,
    Casey
  • Danny Hays
    February 10, 2009 at 4:42 pm
    Wheather it’s WMV, MPG, AVI, increasing the bitrate while leaving the resolution at 640 x 480 will improve the quality without changing the resolution or aspect ratio. Danny Hays
  • Casey J porter
    February 10, 2009 at 4:50 pm
    How I can I go about doing that?
    Casey
  • Jeremy Rasnic
    February 10, 2009 at 7:48 pm
    To do that, you would need the pro version of Vegas as this is not a feature implemented in the consumer versions.
    j razz
