Activity Forums Maxon Cinema 4D rendering issue in 11.5
  • rendering issue in 11.5
    Posted by Laurent Heid on September 22, 2009 at 5:03 pm
    Hi, I’m trying to find out the reason of render speed discrepancy between a perspective camera and an orthogonal view in cinema this is my test file:
    https://www.cubicdesign.fr/drew/rendertimeproblem.rar
    In the perceptive view I’ve dollyed a camera far enough and then zoomed in to imitate cinema’s Top view.
    the thing is, a perspective camera renders much faster then the Top view when sent to the “picture viewer”(do not render “active view”, alternately set each panel to be used as render view).
    Just note the render time in the picture viewer for the first half irradiance cache prepass to go down (for the little squares to reach the bottom)
    the results I have:
    a dual intel core: left (perspective) panel 2:03mns, right (top) 4:44mns
    a quad intel core: left panel 1:16mns, right 3:14mns
    Any idea how to get the same render speed from an orthogonal view? this is crucial for archvis and product presentation.
    Note: substituting a parallel camera yield no speed gains.
    thanks, Lh
    What?
    cubicdesign.fr
    Adam Trachtenberg replied 17 years ago 2 Members · 3 Replies
  • Adam Trachtenberg
    September 22, 2009 at 8:07 pm
    I’m not sure what the cause is, but I suspect it has to do with the way that rays are cast from the camera. Perhaps shooting rays parallel from an orthographic camera plays havoc with the scattering algorithm.
    That said, the total rendering time (albeit at 1/10th scale) was about the same for both views.
    I will offer you this tip, though: in 11.5 there is now a
    small fragments option in the antialiasing tab where you can chooseo choose between hybrid, raytrace only, and scanline only. In scenes like this with very high per pixel detail, the raytrace only option can provide a significant speed up. In my 1/10th scale test it produced a 33% improvement.
  • Laurent Heid
    September 22, 2009 at 11:29 pm
    Thanks Adam for looking into the issue, I will try the small fragments option. couple days ago a top view render took 7.5 hours completely throwing off all schedule for a job. The perspective camera finished in 20mns, that is a huge delta making orthogonal views and parallel camera useless for some scene configuration.
    What?
    cubicdesign.fr
  • Adam Trachtenberg
    September 23, 2009 at 5:00 am
    Yeah, sorry I couldn’t be of more help. You should probably submit it to Maxon tech support so they can sort out whether it’s a bug or a limitation.
