Activity Forums Adobe After Effects Rendering in Vector format – to use in Cinema 4D.
  • Rendering in Vector format – to use in Cinema 4D.
    Posted by John Fisher on January 15, 2013 at 9:31 am
    In the past out of habit I’ve created a make around an image/shape in Illustrator CS3 and saved as a vector .ai file. I import that into Cinema 4D and away I go. However using After Effects I haven’t and I’d like to.
    Say I have an image/logo, I import into a composition and use either a mask tool, maybe auto trace or roto brush even. I have a mask over the image. Do you know how can I save that one frame of the composition with the mask as a vector format so I can use in Cinema 4d?
    John Cuevas replied 13 years, 8 months ago 2 Members · 1 Reply
  • John Cuevas
    January 15, 2013 at 3:10 pm
    Can’t save it out of AE that way. If you have already done the work, you might be able to copy the paths and paste them in Illustrator. I know you can paste from Illustrator to AE, so it should work the other way around.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
