Activity › Forums › Apple Final Cut Pro Legacy › Rendering in RGB or 8-bit YUV
Antonbradley
April 23, 2007 at 4:22 pmHi Rafael,
I have found a workaround:
I changed my codec from DV PAL and 8 bit YUV render to 10 bit uncompressed & RGB render
This is the ONLY way that some of the banding artifacts go away and the Knoll light effect renders correctly (note this works on some sequences and not others but is better than nothing)
But now the test sequence
