Activity Forums VEGAS Pro Rendering in PAL
  • Rendering in PAL
    Posted by Allen King on March 24, 2010 at 12:56 pm
    I’m rendering a wedding in PAL so a couple can send it to family in Italy, how will I know if it worked?
    Ben Longden replied 16 years, 5 months ago 4 Members · 3 Replies
  • Martin Phillips
    March 24, 2010 at 1:00 pm
    A lot of DVD players are switchable. Also, if you are using a vegas pal template (with out changing it) it should be fine.
  • Odd Magne nilsen
    March 25, 2010 at 6:16 am
    If possible, shoot 24p.
    odd magne nilsen
    newbie
  • Ben Longden
    March 27, 2010 at 2:28 am
    Just shoot as normal if you are in NTSC land.
    Do the conversion in post.
    Edit and cut to your hearts delight and save as a .avi file, in NTSC format. Then re-import the file onto the timeline, changing Vegas’ preferences to PAL (either 16;9 or 4×3 depending on what you shot).
    When you do this change the custom control to 8Mbps variable bit rate, two pass.
    Then change DVDA presets to that of Vegas (eg PAL Widescreen) and toast to disc from there.
    As a general rule of thumb, if you DONT hear from the client, everything went OK.
    ben
    Do unto others…
