Activity Forums Apple Final Cut Pro Legacy Rendering in FCS2
  • Rendering in FCS2
    Posted by Jon Slagle on June 9, 2007 at 7:35 pm
    Some strange things happening in FCS 2
    I’ve been getting extremely long rendering times ie. 4 hours for a :30 commercial 48 hours for 30 min infomercial. any Ideas – I’ve tried different codecs – DV / 10 bit uncompressed and ProRes 422 and they all seem to render out the same. I’ve reinstalled the Black Magic drivers for universal. This is killing me timewise
    Also since I have shake installed I’m told by apple that qmaster is the culprit on why I can’t render anything in compressor. Any help would be greatly appreciated.
    Herb Sevush replied 19 years, 3 months ago 4 Members · 3 Replies
  • Greg Nosaty
    June 9, 2007 at 8:42 pm
    I’m also experiencing very long render times. I have a 30 second credit sequence thats made in Motion with static pages of white text on black, no movement at all and it takes 8 minutes to render in 10bit uncomressed.
  • Ben Insler
    June 9, 2007 at 9:36 pm
    I don’t know the answer to this – haven’t picked up Studio 2 yet…but I’ve seen some other posts on here about long render times. Have you guys searched in the archives?
    -Ben
  • Herb Sevush
    June 11, 2007 at 1:54 pm
    Jon –
    This is a definite problem with FCS2. Here’s an earlier thread on this topic.
    https://forums.creativecow.net/readpost/8/940941?
    The workaround seems to be to change rendering from “best” to “normal” in preferences. You will see artifacts this way, it’s only good for rough cuts, you’ll have to re-render at “best” for output.
    The only thing to do is give feedback to apple and pray for a fix.
    Herb Sevush
    Zebra Productions
