Activity › Forums › Apple Final Cut Pro Legacy › Rendering in FCP vs. Premiere
  • Rendering in FCP vs. Premiere
    Posted by Mark Mallett on August 25, 2011 at 11:04 pm
    I am testing out Adobe Premiere 5.5. The first thing I noticed is when I add a filter or effect (from a third party like Sapphire eg.), Premiere plays it back without needing rendering!! But in FCP, every stinking little thing I do has to be rendered. My Sequence/footage settings are correct, so basic playback doesn’t require rendering. But it’s when I add effects that FCP becomes an exercise of watching a progress bar 90 percent of the time.
    I thought FCP, especially v. 7, which is what I’m using (FCP Studio 3), allowed you to view clips without having to render them? FCP X does, Adobe does, but not FCP 7. Are my settings wrong, or is this simply how the software works? Is there something I can change?
    Emanuel Ach replied 15 years, 1 month ago 3 Members · 3 Replies
  • Shane Ross
    August 25, 2011 at 11:49 pm
    Only certain FXPlug effects in FCP 7 don’t require rendering to view. And they depend on the graphic card you use. But Adobe has ALWAYS been better about filters and rendering…
    Shane
  • Mark Mallett
    August 25, 2011 at 11:50 pm
    I was afraid you were going to say that. Maybe it’s time to leap over to Premiere for good….
  • Emanuel Ach
    August 26, 2011 at 7:47 pm
    premier has only um 4 cams multiclip max 😉
    just to let you know
