Activity › Forums › Adobe After Effects › rendering in AE HDV to be imported in fcp
Kevin Camp
September 7, 2007 at 5:07 pmthanks beeny for the ub version of apple’s hdv codec…
i was able to test the render with the two output modules, one for lossless full 1080 rez and the other for hdv1080…
you can, infact, render the same comp to the different frame sizes. i assume its because hdv is only a 1.33 par, so it forces the frame size conversion… so that’s pretty cool. the hdv file did come back in to ae interpretted as square px, but that’s easy enough to override.. not sure if that would create problems for other software, but i doubt it would be a big issue.
Kevin Camp
Designer – KCPQ, KMYQ & KRCW -
Brendan Coots
September 8, 2007 at 8:35 pmCool I’m glad everything worked out. So many intricacies, sometimes this line of work gets CRAZY!
