Activity Forums Maxon Cinema 4D Rendering hi-res similar to low-res
  • Rendering hi-res similar to low-res
    Posted by Shadow Cluster on September 30, 2014 at 11:11 am
    Hey, guys! Anybody can help me with such question? I want to render a very hi-res image, for example 8000×5000, but i need maximum similarity to low-res rendering, maybe looking like in viewport render. Do you understand what i mean? I don’t need extra details in hi-res render, extra reflections, sharp details etc… Maybe there are some techniques to get similar result, scaling project or something else? Thanks!
    Emir Bojorquez replied 11 years, 11 months ago 2 Members · 3 Replies
  • Emir Bojorquez
    October 2, 2014 at 12:17 am
    You can change the settings of your render if you go to Render >>Edit Render Settings>> OPTIONS
    and also ATI-ALIASING
    and reduce the setting till you get what you are looking for.
    If, on the other hand, you are looking for a similar look to the Viewport Editor you could use Hardware Render.
    Good Luck
    Imagination is the best tool…
  • Shadow Cluster
    October 2, 2014 at 2:24 am
    Thanks for the answer! Hardware Render is not that thing i’m looking for. I need normal render, but… how to explain… i need, for example, scale of lights reflections in hi-res the same as i see at viewport render resolution. When i render high-res, reflections go smaller, sharper with much more extra details and overall lighting of a scene doesn’t look like at low-res…
  • Emir Bojorquez
    October 2, 2014 at 4:25 am
    even though i understand what you describe, an image of you Get and another one of what you Want will help us to have a better idea of your final goal.
