Activity › Forums › VEGAS Pro › Rendering HD video for iphone?
  • Rendering HD video for iphone?
    Posted by John Smith on August 26, 2010 at 6:54 pm
    Hi guys, can anyone tell me what format and rendering settings/template I should use to render full HD video to a format and resolution that people can download to view on their iphone (3G/3GS and 4)?
    Many thanks!
    Mike Kujbida replied 16 years, 1 month ago 2 Members · 1 Reply
  • Mike Kujbida
    August 26, 2010 at 7:22 pm
    Here’s what a user on another Vegas forum did and it worked for him.
    1. 720p (1280 x 720), MPEG4, 30.00 fps (but if you are using Vegas, it doesn’t have that option, so use 29.97), video bit rate 1200 kbps. You can go a bit higher, but the files get proportionally bigger.
    3. Audio codec MPEG4 AAC-LC, stereo, bit depth 16, 48000 Hz sample rate. If you are not using Vegas and you need an audio bitrate, use 128000)
    4. Wrapper: MOV (but MP4 will work also, if you use a different codec)
    Lower resolutions and higher bitrates will also work, as will Motion JPEG.
