Activity › Forums › VEGAS Pro › rendering hd to dvd workflow
  • rendering hd to dvd workflow
    Posted by Campbell Killick on March 18, 2013 at 12:27 am
    Sorry if this has been asked a million times before but I have searched without Joy.
    My camera will only shoot HD but all of my projects end up as DVD or other files of sd quality.
    Sony vegas really dosent like to render HD to SD and its doing my head in.
    I have tried matching the project properties to the rw footage (HD) before editing and rendering but when I try to render to DVD the output is unwatchable (frames dropped and shudder)
    SO I choose “match project settings” and try to render Mainconcept MPEG-2. THis is very slow and produces a monster file that needs to be re-rendered in DVD architect.
    So I am left trying to do a work-around. I could pre-convert all my footage to SD or I could get a SD camera but Im thinking vegas should do this relatively simple task.
    If somone could talk me through a workflow in simple terms – or even point to a tutorial I would be eternally grateful.
    Rich Kutnick replied 12 years, 10 months ago 3 Members · 6 Replies
  • Mike Kujbida
    March 18, 2013 at 10:06 am
    [Campbell Killick] “Sony vegas really dosent like to render HD to SD and its doing my head in.”
    Yes it does because a lot of us on here, myself included, do it all the time.
    “I have tried matching the project properties to the rw footage (HD) before editing and rendering but when I try to render to DVD the output is unwatchable (frames dropped and shudder)”
    What’s the make and model of your camera? What are your project properties?
    “SO I choose “match project settings” and try to render Mainconcept MPEG-2. THis is very slow and produces a monster file that needs to be re-rendered in DVD architect.”
    For an SD DVD, you have to render your video to an appropriate MPEG-2 template and your audio to AC-3.
    Fill in some of the requested details and I’m certain that we can help you.
    Also, please post your computer specs (OS, RAM, # and size of hard drives, etc.) and your version of Vegas (Pro or Movie Studio).
  • Campbell Killick
    March 18, 2013 at 11:45 am
    Thanks for the quick reply Mike
    So here is my system info
    OS Name Microsoft Windows 7 Home Premium
    Version 6.1.7601 Service Pack 1 Build 7601
    System Manufacturer HP-Pavilion
    System Model VG247AA-ABU p6217uk
    System Type x64-based PC
    Processor Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz, 2499 Mhz, 4 Core(s), 4 Logical Processor(s)
    BIOS Version/Date American Megatrends Inc. 5.09, 19/08/2009
    SMBIOS Version 2.5
    Installed Physical Memory (RAM) 6.00 GB
    Total Physical Memory 6.00 GB
    Available Physical Memory 2.68 GB
    Total Virtual Memory 12.0 GB
    Available Virtual Memory 7.93 GB
    Im shooting with a panasonic hdc-sd700
    I have tried a range of project properties.
    Either “match media video settings” which give Custom (1280×720, 25.000 fps) or the DVD template PAL DV (720×576, 25.000 fps)
  • Mike Kujbida
    March 18, 2013 at 1:08 pm
    Campbell, you need to be aware that, compared to newer machines, your computer is quite slow which means long render times.
    I looked up your camera and it shoots either 1920 x 1080 50p or 50i.
    My guess is that you have it set to 50p which is why you’re experiencing some of your problems when rendering to DVD.
    It’s OK to match project properties but there is one “gotcha” to be aware of and that’s the “blend” vs. “interpolate” setting.
    John Rofrano does an excellent job of explaining this in the Jittery footage (field flicker?) thread.
    Follow his advice and you should be ok.
    The other issue is rendering for DVD.
    As I said earlier, you have to render your video to MPEG-2 and your audio to AC-3. Give both files the same name and put them in the same folder. That way, when you launch DVD Architect, load the video file and the audio will automatically follow.
    Render using the MainConcept DVD Architect PAL Widescreen video stream template. Use the default settings for now.
    Using a bitrate calculator to optimize render settings has been discussed at length on the other Cow Vegas forum so do a search there for more info.
  • Campbell Killick
    March 18, 2013 at 1:22 pm
    Thanks Mike
    I will check my camera settings and read up on the John Rofrano thread.
    Eventually I will get a better computer
  • Mike Kujbida
    March 18, 2013 at 1:26 pm
    You’re very welcome Campbell.
    Don’t be afraid to come back with more questions as that’s how we all learn.
  • Rich Kutnick
    November 18, 2013 at 2:46 pm
    I would like to delve deeper here. With HD (1920X1080, 60i) source footage, will your final output (on DVD) look/sound better by rendering to MPEG2/AC3 in Vegas, then burn in DVD Architect, OR instead render to an HD template in Vegas, then let DVD Architect compress it down to SD quality for DVD burning?
    Rich Kutnick
    VIDEO IMPRESSIONS
