Activity Forums Adobe Premiere Pro Rendering HD and SD in the same sequence
  • Rendering HD and SD in the same sequence
    Posted by Jake Williams on July 13, 2008 at 5:26 am
    I am working with sequences that incorporate HD and SD footage. The SD is mostly in AVI and Quicktime while the HD is in m2t. Does anyone know if this will cause render problems when I go to output? If so what would be the best fix? Thanks.
    Jake Williams replied 18 years, 2 months ago 3 Members · 3 Replies
  • Vince Becquiot
    July 13, 2008 at 5:55 pm
    As long as your frame rates are the same, you should be fine.
    Vince
  • Glenn Triggs
    July 14, 2008 at 6:08 am
    you might need to make the sd stuff larger in the frame cause the resolution will be differend – do this be simply enlarging it through the effect drop down and size it up.
    -glenn
    http://www.darkepic.net
  • Jake Williams
    July 16, 2008 at 5:01 am
    Thank you for your suggestions. I appreciate it.
