Activity Forums Apple Final Cut Pro Legacy Rendering green spots around text from psd file
  • Rendering green spots around text from psd file
    Posted by Gunleik Groven on June 24, 2006 at 8:43 pm
    Hi.
    Working in a Dvcpro HD 1080 psf 25(dominance set to “none” all over)timeline.
    Combination of files from motion, multilayered psd’s and video.
    The last (of course) psd looks ok in preview but when I render it, green squares appear around the text.
    It is a dual layered psd where the background has some transparency and the foreground is text.
    Weird thing is that I use a lot of identical set up psd’s in this project and all but this works as supposed.
    Any ideas?
    Gunleik
    Bryan Keith replied 20 years, 3 months ago 4 Members · 4 Replies
  • Gunleik Groven
    June 24, 2006 at 8:59 pm
    Odd.
    I turned off the “high Precision” settings – and it worked out.
    Any idea as to why?
    Gunleik
  • Duncan Craig
    June 25, 2006 at 4:59 pm
    If possible change the PSDs to TGAs, photoshop files often render strangely for me too!!
  • Roddy Jamieson
    June 25, 2006 at 7:37 pm
    I get this on PSDs, but only where I have a soft shadow and the settings on High Quality YUV. I posted thsi on the Decklink Forum. They checked this out and found it was an Apple bug, so still no fix?
    I also manifests itself on 3D Transitions.
    Roddy Jamieson
  • Bryan Keith
    June 26, 2006 at 7:41 pm
    This bug has been around for quite some time. Apple REALLY needs to fix this. I usually just save my gfx files as TIFF’s. Sure would be nice to work with layered PSD’s without this happening on occasion.
