Activity › Forums › Adobe After Effects › Rendering from A E to play in Powerpoint 2007 and am not seeing a transparent background
  • Rendering from A E to play in Powerpoint 2007 and am not seeing a transparent background
    Posted by Fred Lexus on May 5, 2012 at 9:23 pm
    Rendering from After Effects to play in Powerpoint 2007 and am not seeing a transparent background in the video. I’ve tried the combos below and included a snapshot of the render queue:
    Which (if any) of the combinations should have produced video with a transparent background? Are there additional values for rendering that I need to change; if so, what are they and what should they be changed to?
    (Additional info:
    – This project was imported from Illustrator (Document profile = Video and Film)
    – Applications: After Effects, Illustrator (both CS5)
    System spec
    Video information: NVIDIA, GeForce GTX 480, driver ver 8.17.12.9573
    Prod Name: After Effects CS5
    Prod Ver: 10.0.2.4
    OS: Windows 7, Ver: 64-bit
    DirX: 11
    Processor: Intel(R) Core(TM) i7 CPU
    Memory: 6.00 GB)
    Combinations
    1.Format – AVI
    Video Codec – None
    Channels – RGB+Alpha
    Depth – Millions of Colors+
    Color – Straight
    Comp background is black
    Transparency grid is on
    2.
    Format – AVI
    Video Codec – None
    Color – Premultiplied
    3.Format – Quick Time
    Video Codec – Animation
    Color – Straight
    4.Format – Quick Time
    Thanks for your assistance
    Nevin Styre replied 14 years, 4 months ago 4 Members · 4 Replies
  • Mathew Fuller
    May 5, 2012 at 11:40 pm
    I could be wrong but I am fairly sure powerpoint doesnt do alpha channels.
    The higher they fly… the much.
    My Reel:
    https://www.youtube.com/watch?v=olElCddRiBg
  • Erik Waluska
    May 6, 2012 at 4:18 am
    I know that powerpoint supports alphas in PNG stills, so maybe try a png sequence?
  • Fred Lexus
    May 6, 2012 at 10:56 am
    Powerpoint supports .avi and .mov file types.
  • Nevin Styre
    May 8, 2012 at 5:39 am
    The only thing I could think of that might support transparency in a moving image in Powerpoint would be a GIF
