Activity Forums Adobe Premiere Pro Rendering for DVD…. settings Adobe Premiere Pro
  • Rendering for DVD…. settings Adobe Premiere Pro
    Posted by Jeff Gart on September 24, 2009 at 3:05 am
    What are the best setting for rendering?
    I am through editing and ready to export/render to encore?
    I want to have the best qual/settings for the dvd playback…
    Kevin Mooney replied 17 years ago 2 Members · 1 Reply
  • Kevin Mooney
    September 24, 2009 at 3:18 pm
    Hello I have just learned how to do this exporting is different for CS3 and CS4 from the file menu in premier Pro find export to encore,Encore will open you can add chapter markers if you wish, select output to DVD and 4.7gb this will use all the disc,once this is done (it takes some time)if you have saved the project you can burn more dvd’s at will
    Kevin
