Activity Forums Adobe After Effects Rendering for Days?!
  • Rendering for Days?!
    Posted by Letitbleed on August 11, 2005 at 7:22 pm
    Hello,
    I keep going through the “Text that blows away like sand”, by Emanuel Eriksson and every time I try to render it seriously takes like 2 1/2 days. I haven’t been able to find help anywhere. I know I had it setup at one time so it didn’t take so long but can’t get it? If ANYONE has any tips or knows of a good tutorial for render settings…Please, Please, PLEASE let me know. 2 days seems very excessive and I know it shouldn’t take that long. Thanks for any help.
    LIB
    Letitbleed replied 21 years, 1 month ago 2 Members · 2 Replies
  • Steve Roberts
    August 11, 2005 at 7:49 pm
    What are your system specs? Platform, processor, RAM?
    To see how your system measures up compared to a standard, go here:
    https://www.media-motion.tv/aebenchmarks.html
    … and render the project both ways. Compare your times to the fastest system listed.
    There should be some fast render tips in the manual if I recall, but if it takes 2.5 days on your system to render a project, no tips will get it down to one or two hours, short of buying a new system.
    Anyway, run the benchmark, then come back here with your system spces and result.
    Steve
  • Letitbleed
    August 11, 2005 at 10:26 pm
    ok, did that and it went way faster and those have to be more intense than the sand tutorial. One thing I noticed is it used like 1.5 gigs of memory and when I try to render it uses maybe 90,000k and that’s it? The psd sequence took maybe a minute and the quicktime burning man video took an hour. If I download the ae file associated with the sand tutorial and render it goes faster….but when I try to do it from scratch, that’s when I run into my rendering problem. I’m running a P4 at 3.4 ghz and have 2 gigs of ram. Which is three times faster and 4 times more ram than the other machine that I had rendering the tutorial in about an hour…So I have to be doing something wrong. I’ve tried the psd sequence with a render farm setup with another computer and that one takes a long time too. I’ve also tried the quicktime render and it takes the same amount of time. Any suggestions? Thanks again.
    LIB
