Rendering files in vegas to export to idvd
Help!
I’m using vegas 6 and have edited a wedding. I’m trying to render the project as a quick time file so i can author the wedding on my Imac using iDVD… for some reason iDVD won’t accept MPEG2.
Anyway, I seem to be able to render smaller files as quick time but when I go to render out a file that’s larger… saye… an hour long… I get the following messgae.
“An error occured writing the file. Make sure you have write access to the file/folder. and that there is enough disk space”.
I have loads of disk space so I can’t imagine it’s that.
Are there special custom settings I should be looking at to render to quicktime so I can author on idvd?
cheers.
