Activity Forums Apple Final Cut Pro Legacy Rendering failure
  • Rendering failure
    Posted by Marty Mcgrath on December 20, 2012 at 4:34 am
    I’m using FCP7 on a Quad Core Mac and overtime I go to render is stops and tells me I don’t have enough memory. Or won’t render my Twixtor plug-gins. I just got this computer off a friend who competelly re fragged it and it has 8 gig of memory and 127gig on the hard drive. Anyone got any idea about hoe to fix this. Cheers Marty
    Marty Mcgrath replied 13 years, 8 months ago 2 Members · 2 Replies
  • Neil Patience
    December 20, 2012 at 2:17 pm
    Hi Marty
    Is it the “Out of Memory” error message ? Do you have stills in your sequence bigger than 4000 pixels in any dimension ? Or high DPI images.
    If so reduce them in size and to 72 DPI
    Thats a very common cause for that error. Not sure about the Twixtor renders, Might be worth the old prefs trash.
    https://www.digitalrebellion.com/prefman/
    I have also heard of people reducing the stills cache setting to 1 to get around this.
    You will find lots of threads here on this error in general
    Hope something there helps
    best wishes
    Neil
    http://www.patience.tv
  • Marty Mcgrath
    December 20, 2012 at 10:35 pm
    Thanks for your help
    There are no stills in the project
