Activity › Forums › Adobe After Effects › Rendering DVCPRO in AFX for NTSC FCP import
  • Rendering DVCPRO in AFX for NTSC FCP import
    Posted by Ed Ethridge on March 5, 2009 at 6:06 pm
    I’m working with DVCPRO25 ftg and I’m exporting same as source QT movies from a DV sequence in FCP and importing it into AFX. I am then creating a DV comp from it using the make comp icon in the project window. I am noticing that when I drop this DV precomp into an NTSC timeline I see what look like small field line issues in the video previews in AFX as well as when I import the files (rendered as FCP 8 Bit Uncompressed) back into FCP and play them back in an NTSC sequence. I am not sure if this is a limitation of my source material or a problem with my pipeline. Any help or comments would be greatly appreciated. Thanks.
    Ed Ethridge replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
