Activity Forums VEGAS Pro Rendering DV – Vegas Pro 9.0
  • Rendering DV – Vegas Pro 9.0
    Posted by Larry Leake on June 16, 2009 at 3:58 pm
    I’m attempting to render a fairly short (5 min) clip of .dv footage to .AVI, using Vegas Pro 9.0. The render begins, and watching Task Manager, the CPU usage spikes to about 80% and then immediately falls off to around 4% – all within the first 5 seconds or so. Then, it just hangs, and the Approximate Time field in the Vegas rendering status dialog just continues to increase. Pressing “Cancel” will not stop the render – the only way I could shut down Vegas was to Logoff.
    There are no effects applied to the clip, other than a dissolve at the beginning and end.
    The identical piece of footage renders without issue in Vegas 8.0.
    Jeremy Rasnic replied 17 years, 2 months ago 2 Members · 1 Reply
  • Jeremy Rasnic
    June 16, 2009 at 9:08 pm
    Just for elimination sake, have you removed the dissolve at the beginning and tried again?
    What flavor of avi are you rendering to? Remember, avi is just a wrapper that can contain any assorted sundry of codec inside.
    j razz
    https://www.jrazzcreations.com
