Activity › Forums › Adobe Premiere Pro › Rendering crashing in CS6
  • Rendering crashing in CS6
    Posted by Alexandra Mcquilkin on October 12, 2013 at 9:32 pm
    A particular project I am working on will not render in cs6. Every time i try to render the timeline it freezes about 1/3 of the way through. I can render one clip at a time for a few clips but then it consistently freezes after about 3 renders and i have to quit and reopen. I will then reopen and be able to render the clip that it previously froze on, leading me to believe its not a problem with the media itself. The media is a mixture of mp4s, movs and flvs that have been converted to DV (in MPEG streamclip). I have tried using a new sequence, i have also tried importing into an entirely new project but continue to have the same problem. I got so frustrated I exported an XML and am now workign easily in fcp7 but i would really like to resolve this. Anyone have any advice?
    Thank you!
    Ericbowen replied 12 years, 11 months ago 3 Members · 2 Replies
  • Chris Gunningham
    October 13, 2013 at 9:19 pm
    As a test could you convert the clips to pro res and then try exporting? I’ve never tried an flv in premiere so that would be my suspicion. I know it doesn’t freeze at the same point but I suspect it’s media related, assuming you’ve checked the obvious like disk space, also what codec are you rendering to?
    Chris Gunningham
    Online/VFX Editor
  • Ericbowen
    October 15, 2013 at 9:34 pm
    Do you have the hardware MPE on or off? If the Hardware MPE is on then switch it to Software MPE mode and then export the sequence. See if it will export.
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
