Activity › Forums › Adobe After Effects › Rendering Cameras
Rendering Cameras
Posted by Harry Robins on May 19, 2014 at 4:02 pmHi, I have made a project with Element 3D and the 3D camera tracker. I have created the camera, and have just finished the effect. However when I go to render it renders the object in the middle of the screen not moving. I have discovered that it has something to do with the Active Camera. When I click to view the 3D Camera Tracker, the object follows sits on the table and follows it. When I select Active Camera it goes into the middle of the screen and stays still. The 3D Camera Tracker is the top layer, and there is no other cameras. Please help. 🙂
HjRobins.
Harry Robins replied 12 years, 3 months ago 2 Members · 9 Replies -
Walter Soyka
May 19, 2014 at 5:05 pm[Harry Robins] “When I click to view the 3D Camera Tracker, the object follows sits on the table and follows it. When I select Active Camera it goes into the middle of the screen and stays still. The 3D Camera Tracker is the top layer, and there is no other cameras.”
Does your 3D Camera Tracker layer extend through the whole shot? Can you post a screenshot?
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Harry Robins
May 19, 2014 at 5:48 pmI rendered the first second or so, it seems like it follows the camera, then springs back. https://reels.creativecow.net/film/render
HjRobins.
Walter Soyka
May 20, 2014 at 1:16 amDoes the springing back coincide with any of the layers ending or splitting?
Walter Soyka
Harry Robins
May 20, 2014 at 6:32 amNo, it’s like one second in. 20 something frames. When I change the view to 3D Camera Tracker, it shows what I want to render, but whenever I click Active Camera it goes back to the middle.
HjRobins.
Walter Soyka
May 20, 2014 at 12:38 pmThat is very strange. I don’t see any reason in your screenshot as to why the camera tracker camera wouldn’t be the active camera.
Does clearing your cache help?
What about making a new comp and pasting these layers into it?
Walter Soyka
Harry Robins
May 20, 2014 at 4:53 pm -
Walter Soyka
May 20, 2014 at 5:24 pmNo jumping here. Since I didn’t have your assets, I just threw a cube in the Element effect, and it played through smoothly.
I suggest you clear your cache. Edit > Purge > All Memory & Disk Cache.
Walter Soyka
Harry Robins
May 20, 2014 at 5:38 pmI think I’ve fixed it. I had to start all over again though. 🙁 But at least I got the effect I was looking for. Thanks for helping.
HjRobins.
