Activity Forums DaVinci Resolve Rendering bug with tracked windows on off-speed clips?
  • Rendering bug with tracked windows on off-speed clips?
    Posted by Mel Matsuoka on October 6, 2011 at 11:03 pm
    I’m running into a weird problem with Resolve8.0.1. I have a clip in my session that was slowed down to 50% in FCP. I’ve tracked a CPW on this clip, and it looks just fine when I play it back in realtime from within Resolve.
    But when I render this clip out, the window does not track or animate at all. It just stays put in the same position that the window is in on the 1st frame of the clip.
    Other tracked windows in the same session render fine, though.
    Is this a bug, or am I overlooking something here?
    Robert Due replied 14 years, 11 months ago 3 Members · 3 Replies
  • Sascha Haber
    October 7, 2011 at 5:39 am
    I guess overlooking…maybe there is something in the render settings set up wrong ?
    Like Source mode, or its rendering a different version , or Flat pass is on ?
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Mel Matsuoka
    October 7, 2011 at 6:02 am
    It’s not any of those, actually. The problem only seems to be happening on a clip that has the speed change in it. It’s the only version in the versions stack, too.
  • Robert Due
    October 7, 2011 at 4:34 pm
    Try tracking the shot at normal speed, render and redo the speed change back in FCP.
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
