Activity Forums Adobe After Effects Rendering Alpha Channel in .FLV, and Motion Blur
  • Rendering Alpha Channel in .FLV, and Motion Blur
    Posted by Spencer Tycksen on February 3, 2012 at 2:12 pm
    Two questions:
    Will motion blur be rendered out if have checked the motion blur box on certain layers, but have not clicked the “enable motion blur” button at the top?
    I need to export an alpha channel as a .flv. When I select FLV, the option to select RGB + Alpha becomes grayed out. How do I do this?
    Spencer Tycksen replied 14 years, 7 months ago 2 Members · 2 Replies
  • Ben G unguren
    February 3, 2012 at 4:30 pm
    “Will motion blur be rendered out if have checked the motion blur box on certain layers, but have not clicked the “enable motion blur” button at the top?
    YES
    I need to export an alpha channel as a .flv. When I select FLV, the option to select RGB + Alpha becomes grayed out. How do I do this?”
    I have an Output Module preset called “FLC with Alpha” (AE CS 5.0, OS X). Can you find that in the Output Module presets (the drop-down box)?
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Spencer Tycksen
    February 3, 2012 at 5:32 pm
    Ben, thank you for your response. Through some trial and error I was able to figure out my problem. With the output module window pulled up, I clicked on format options in the video section. Under Basic Video Settings, I needed to check “Encode Alpha Channel.” That enabled me to select RGB + Alpha on the main window.
    Thanks for answering my question about motion blur.
