Activity Forums AJA Video Systems Rendering AE SD uncompressed settings for Kona 2 import.
  • Rendering AE SD uncompressed settings for Kona 2 import.
    Posted by Craig Meadows on January 6, 2006 at 9:30 pm
    Have two Kona 2 systems, just got a seperate G5 quad for After Effects, Maya, etc.. On the AE machine how do I tell AE to render 8-bit uncompressed for the Kona 2 systems? …AE output module shows all the standard QT codecs plus “none” for uncompressed…is that it?…or can I install the AJA codecs somehow?
    Craig Meadows replied 20 years, 8 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    January 6, 2006 at 10:49 pm
    Kona uses the apple codecs and you must install the uncompressed codecs from your FCP machine to your AE machine.
    Look in your Hard Drive>library>quicktime folder and look for the FCP Uncompressed 422.component file.
    Take that file and drop it in the same folder on your AE machine.
    Good luck.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Craig Meadows
    January 7, 2006 at 3:35 pm
    Thank you so much Jeremy.
