Activity Forums Adobe After Effects rendering ae projects to different formats
  • rendering ae projects to different formats
    Posted by Zach Blumstein on September 3, 2008 at 9:08 pm
    hi i need to render a 1280×720 comp at 16:9 aspect ratio
    for the following formats
    web
    film
    dvd
    television
    ipod
    can someone give me some tips for rendering to all these different formats as to whether its best to render and compress using ae
    or if i should use quicktime pro
    thanks
    zach
    Brendan Coots replied 18 years ago 2 Members · 3 Replies
  • Brendan Coots
    September 4, 2008 at 2:14 am
    Without question, I would definitely render an uncompressed quicktime (or animation codec) out of After Effects, and use Quicktime Pro or some other compression application for the various formats you need.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Zach Blumstein
    September 4, 2008 at 3:34 pm
    ok do you have any preset reccomendations
    for quicktime pro if i need to compress for film dvd and tv
    thanks
    zach
  • Brendan Coots
    September 6, 2008 at 7:42 pm
    For film, you should contact the facility that will be doing your film-out. They will likely prefer an image sequence, such as SGI frames, but you need to ask them.
    For DVD, you need to compress to MPEG-2, the only file format DVDs allow. You should really use your DVD authoring program, by feeding it the uncompressed/Animation codec file and allowing it to create the MPEG-2.
    For TV, you will probably want an uncompressed 8-bit file, although most TV facilities will accept (or require) other formats. This is another situation where you are better off contacting the station that will air your spot/show and ask them what they prefer. Some won’t accept digital files and will expect tape-based delivery, such as Beta-SP, etc.
    Brendan Coots
    Splitvision Digital
