Activity › Forums › Adobe Premiere Pro › Rendering a Pro Res file with 16 tracks of audio
  • Rendering a Pro Res file with 16 tracks of audio
    Posted by Matt Chapman on August 25, 2015 at 7:35 pm
    Hey there-
    I am trying to match the settings of a previously rendered file. The file that I am rendering is a simple conversion of a 23.978 ProRes quicktime with 16 channels of audio (a 5.1 mix, stereo master, and stems of music and sfx, etc). I am trying to follow the advice of the post below but something is happening in the render which I can’t understand:
    https://strypesinpost.com/2012/11/exporting-multichannel-quicktimes-in-premi...
    I can import it into Premiere easily, and all 16 Tracks of audio show.
    I have a new sequence which I create, and I make it using the following settings:
    23.976, 2 tracks of video (to add a new slate to the top), and 16 tracks of audio.
    When I render, I am using the following settings for audio :
    THE PROBLEM:
    When I open this newly created file in Premiere, it does indeed have 16 channels of audio and plays just fine. I can hear everything.
    However, when I open the file in Quicktime, no audio plays or is present. The original file (with 16 channels of audio) plays fine in Quicktime.
    I read something online about setting channels in the audio mixer to be 1+2, 3+4, etc. However this seemed strange to me as in that case I couldn’t specify exactly which track they were. I found the below post on the topic, and I get as far as the “1+2” and “3+4” etc, but then I am missing the option as outlined below:
    Does anyone know why I can’t seem to find this option in the dropdown, or how I specify which track goes to which number… and if this is related to why I can’t hear any audio when playing in Quicktime?
    thanks!
    Chapman
    Matt Chapman replied 11 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
