Activity › Forums › DaVinci Resolve › Rendering 5K footage to 4K 1.78 (4096×2304)
  • Rendering 5K footage to 4K 1.78 (4096×2304)
    Posted by Andrew Smith on May 8, 2012 at 7:23 am
    Just curious if it is enough alone to make that custom setting in timeline format before rending full res premium ProRes444 – when i launch a test render in QT7 i notice there is some black lines and its not full frame – is this correct? I am going SDI out to a 1080 monitoring solution btw however i can only attempt zooming in a bit in the GUI.
    I have tried going to the output tab to zoom in a bit but i am finding that not so accurate as a method (hard to see what I am doing) so before doing a test like that i want to make sure I am doing this correctly in Resolve.
    Any advice?
    Andrew Smith replied 14 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
