  • Posted by Quentin Block on December 5, 2007 at 10:12 pm
    I’m using a lot of simple fades as transitions, Sometimes they need to be rendered.
    There are choices: Render Selection, Render All, Render Only.
    I’ve read the manual about this and it’s still confusing.
    I seem to get the results I want using “Render Only – Needs Render”.
    But sometimes I go to my computer and find it rendering (seemingly on its own) dozens and dozens of shots and it seems to be putting them all onto my hard drive in a Render folder (?!).
    I just want to render transitions the fastest way so I can view and keep working. Then when I’m ready I want to output the whole file in the best resolution to save as a Quicktime movie for various uses.
    Can anyone explain how I can quickly render transitions and avoid this (seemingly arbitrary) auto render of my sequences?
    I don’t want to cram my Hard Drive with all these files that I didn’t ask for.
    Also, How do I make sure that I’m getting the highest quality render of sequences+ their transitions when I’m outputting as a Quicktime?
    Thanks for any advice!
    Dan Wharmby replied 18 years, 9 months ago 3 Members · 2 Replies
  • Bouncing Account needs new email address
    December 6, 2007 at 8:23 am
    For highest quality, you should render ALL transitions before you output.
    Generally speaking, the render files are relatively small.
  • Dan Wharmby
    December 6, 2007 at 11:51 pm
    I usually just highlight the transition and hit Apple R to render just that segment. I’m not sure what you mean when you say “highest quality.” Depends on how you are exporting and for what end use. If size is not a factor, self contained quicktime movie will give you the same settings as your sequence.
    Daniel Wharmby
    Blogs at: compressionista
