  • Posted by Wolfgang Shumacher on August 14, 2006 at 11:26 pm
    I have the red line…indicating that the video needs rendering, in this case some disolves. But when I give the all render command, it wouldn’t render. What am I doing wrong?
    I appreciate your help.
    PrimaW
    Wolfgang Shumacher replied 20 years ago 3 Members · 3 Replies
  • Walter Biscardi
    August 15, 2006 at 1:21 am
    Look at Sequence > Render All and ensure that the Red Needs Render line has a checkmark next to it. If it doesn’t, click it to check it.
    As a general rule, I leave everything checked in all the Render settings.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Bret Williams
    August 15, 2006 at 4:40 am
    You’d think that would be the default wouldn’t you?
  • Wolfgang Shumacher
    August 18, 2006 at 6:17 pm
    Walter, your suggestion worked wonderfully. The color lines were not check-marked, although I don’t understand how they got unchecked.
    Now my system is working.
    Thanks.
