Activity Forums VEGAS Pro Rendering 10GB of AVCHD onto 1 DVD?
  • Rendering 10GB of AVCHD onto 1 DVD?
    Posted by Will Brown on August 28, 2010 at 9:11 pm
    Hi Guys,
    I hope you can help.
    I would like to burn about 10GB of AVCHD footage from my Canon HF100 onto 1 DVD.
    Please can someone advise what format to render it in, so that it wont take too long and will be less than 4.7GB.
    My original stats are:
    1440×1080
    25fps
    8bit
    1.3333
    I am torn between Sony AVC or MPEG2 or something else?
    I have tried using ‘Xilisoft DVD Creator 6’ to just burn the files onto DVD, but it failed.
    I don’t really have to edit them, just burn them.
    Shall I buy DVD Architect Pro 5, would that help/burn AVCHD direct?
    Thanks in advance.
    Will
    https://www.willbrownltd.co.uk
    John Rofrano replied 16 years ago 2 Members · 1 Reply
  • John Rofrano
    August 29, 2010 at 1:57 am
    10GB doesn’t tell us how long the files are in length.
    You can burn about 1 hr 17 minutes of 8Mbps AVCHD onto a single DVD. If the video isn’t that long, 15MBps will get you about 40 minutes of video per DVD (which is probably what the Canon HF100 shoots). If you use a dual-layer DVD you can get 1 hr 10 minutes of 15Mbps AVCHD on it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
