Activity Forums Apple Final Cut Pro Legacy Rendered sequence plays back blue?
  • Rendered sequence plays back blue?
    Posted by David Darrow on January 17, 2008 at 10:50 pm
    I just put FCP 6 on a new 17′ MBP. After capturing video and creating a composite with a PNG background, I rendered the sequence and on playback, it turns blue. I can view individual frames fine, and if I go into the render files, I can play the actual clip fine but just not in the sequence. It looks like I put a colorize hue filter on it. Anyone know what is wrong?
    David Darrow replied 18 years, 8 months ago 2 Members · 2 Replies
  • Adam Taylor
    January 18, 2008 at 12:33 am
    I have had this problem also, and its not just blue…i’ve had allsorts of colours! Do you find the entire clip gets coloured or is it just a section?
    My problem was random sections of a clip become coloured.
    I never found the cause, but it tended to happen when i had several layers of logos being comped onto a video track. It also happened when i used a motion file overlayed onto a clip, if i was using the fcp renderer instead of rendering the shot in motion first.
    adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
  • David Darrow
    January 18, 2008 at 12:56 am
    Well its blue with a bit of cyan, like i’m losing the red channel completely. I have only 2 or 3 layers, and when the timeline is paused, it looks fine. The actual render file looks fine too, but playback in the canvas is blue/cyan. It’s really weird.
    d3 `-{>
