Activity › Forums › Apple Final Cut Pro Legacy › Rendered *.mov file has extra frames
  • Rendered *.mov file has extra frames
    Posted by Amit Ghildiyal on April 29, 2009 at 8:39 pm
    I am rendering out a 4 hour long show through four nested sequences of 1 hour each. I make sure that the in and out points are set properly and that the duration of the clip is exactly an Hour. The settings are for broadcast (dv/dvcpro at 29.97). The procedure was followed before and things were fine, but recently, when I render out the files and play them in QT player and check the info (command + i) the duration it shows is 0:01:00:00:03, although in the timeline the file ends exactly at an hour. Even other players show it as exactly an hour but I want to be sure.
    In the past the files we re exactly 0:01:00:00:00.
    Any help will be appriciated.
    Amit
    Amit Ghildiyal replied 17 years, 5 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    April 29, 2009 at 8:58 pm
    DOn’t trust the Quicktime reporting, trust the reimported FCp time.
    Jeremy
  • Amit Ghildiyal
    April 30, 2009 at 1:02 am
    Thanks for your help Jeremy
