Activity Forums Apple Final Cut Pro Legacy Rendered Clips Will Not Save
  • Rendered Clips Will Not Save
    Posted by Rudy Moni on June 10, 2011 at 10:30 pm
    When I render clips in the timeline ( like a greenscreen composite clip ) and save it to the browser . . . when I bring the clip back into the timieline later it needs to be rendered again. Is there a way to save the rendered clip so that I do not have to render it again? Thank you
    Rudy Moni replied 15 years, 2 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    June 10, 2011 at 10:44 pm
    Render files can only be saved in sequences. so you might save a small sequence instead?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Rudy Moni
    June 15, 2011 at 9:12 pm
    Hello Jerry,
    I appreciate the response. I did that by “accident” once. It seems like the way to go.
    Thank you,
    Rudy
